Meldas 86M, Loading Special Fixed Cycles G34 Thru G37
Need help loading Special Fixed Cycles G34 Thru G37. Long story short, lost all memory on an Okk mill with a Mitsubishi Meldas 86M control. Was able to initialize the memory, get all of the parameters, fixed cycle and parts programs back into control. Not sure where to load these "Special fixed cycles" as the fixed cycle memory only allows programs labeled 72 thru 89. I tried loading them in with the parts program but when a G34 was called, the machine did not run it. OKK could not help me and said that I needed to speak with Mitsubishi. I called Mitsubishi and they told me that nobody there has experience with this control. The manual has a copy of the programs but does not have a procedure for loading anywhere.
