i have list the MITSUBISHI CNC Option Table , support all mitsubishi cnc series , and support citizen / mori seiki system.
anyone need the option , can send me email , kele225@163.com
001 # ?-part system synchronous thread cutting
002 # 3D Machine Interference check
003 # 3D solid program check
004 # 3-dimensional tool radius compensation for 5-axis machining
005 # 3-dimentional circular interpolation
006 # 3-dimentional coordinate conversion?G68?
007 # 3-dimentional tool radius compensation
008 # 3rd, 4th language function
009 # Adaptive control(Load monitoring 2)
010 # Alarm guidance
011 # Anshin-net service
012 # APLC
013 # arbitrary reverse run(M)
014 # Automatic coil switch
015 # Automatic tool length measurement
016 # Automatic tool nose radius offset (Auto Determination Dir.) (for MORI SEIKI)
017 # Axis detachment
018 # Balance cut
019 # Ball screw thermal expansion compensation
020 # Ball screw thermal expansion conpensation
021 # Buffer correction
022 # Built-in PLC capacity 128K?for MORI SEIKI?
023 # Bus connection to receive Magnetic axis
024 # chinese
025 # chinese?Simplified Chinese characters?
026 # Chopping
027 # Chuck/Tailstock barrier check II
028 # Circular cutting
029 # Circular feed in manual mode
030 # Circular radius error compensation
031 # Circular thread cutting
032 # Common memory for part systems
033 # Compensation data input by program
034 # Compound type fixed cycle for turning machining I/II
035 # Computer link B
036 # Constant surface speed control
037 # Control axis superimpositioning
038 # Control axis synchronization across part systems
039 # Coordinate rotation by parameter
040 # Coordinate rotation by program?G68.0?
041 # Corner chamfering/Corner R
042 # Corner chamfering/Corner R?I,Kdirection?
043 # Credit system
044 # Cyclic error compensation
045 # Cylindrical interpolation
046 # Czech
047 # C????????????????????
048 # D specifications drill center
049 # DDB(for MORI SEIKI)
050 # Direct Socket communication I/F
051 # Dutch
052 # Exponential interpolation
053 # Extend workpiece coordinate system selection(300sets)
054 # Extend workpiece coordinate system selection(48sets)
055 # Extend workpiece coordinate system selection(96sets)
056 # Extended drive unit connection I/F
057 # Extended machine error compensation ???1024? + ??384??
058 # Extended machine error compensation ???1024? + ??4096??
059 # Extended variable for Machine tool builder macro(Hold 200sets/Not hold 1000sets)
060 # external device program call
061 # External machine coordinate system compensation
062 # External machine coordinate system compensation(Compensation number input method)
063 # External search
064 # Feed per revolution
065 # Figure rotation
066 # Fixed cycle for turning machining
067 # FL-net
068 # For pitch error compensation, Extended 18 axes
069 # French
070 # Front IC card mode
071 # G code guidance
072 # G specifications grinder
073 # G83 small-diameter deep-hole drilling cycle
074 # Geometric command
075 # German
076 # Graphic check
077 # Graphic trace
078 # Groove width tool offset ?for MORI SEIKI?
079 # Hard disk mode/Floppy disk mode
080 # Helical interpolation
081 # hi-accu acc/dec t-const ext (M)
082 # High-accuracy control function?G61.1/G08?
083 # high-accuracy skip
084 # High-speed High-accuracy control I?G5.1Q1?
085 # High-speed High-accuracy control II?G5.1P10000?
086 # High-speed machining mode I?G5P1?
087 # High-speed machining mode II?G5P2?
088 # High-speed machining mode III
089 # High-speed program server mode
090 # High-speed synchronous tapping
091 # Hungarian
092 # I/O link [GOP??]
093 # Inch/Metric changeover
094 # Inclined axis control
095 # Inclined oscillation
096 # Inclined surface machining command
097 # Input command increment tenfold
098 # Input mistake check warning
099 # Inverse time feed
100 # Involute interpolation
101 # Italian
102 # Korean
103 # L specifications lathe
104 # Least command increment 0.1?m
105 # Least control increment 0.001?m??nm)
106 # Least control increment 0.01?m??0nm)
107 # Linear angle command
108 # Load monitoring
109 # Lost motion compensation
110 # M code command Interlock [GOP??]
111 # M code outoput during axis positioning
112 # M specifications machining center
113 # M2??????
114 # M64 A type selection
115 # Machine rotation center error compensation
116 # Machine tool builder macro
117 # Machine tool builder macro (1280m)
118 # Machine tool builder macro (160m)
119 # Machine tool builder macro (320m)
120 # Machine tool builder macro (640m)
121 # Machine tool builder network system
122 # Macro interruption
123 # Manual coordinate system setting?for MORI SEIKI?
124 # Manual feed for 5-axis machining
125 # Manual feed rate B surface speed control
126 # Manual feed rate command
127 # Manual skip
128 # Manual skip(for MORI SEIKI)
129 # Manual tool length measurement 1/2
130 # Memory capacity 1000KB?2560?/1000programs?
131 # Memory capacity 125KB?320?/200programs?
132 # Memory capacity 2000KB?5120?/1000programs?
133 # Memory capacity 230KB?600?/400programs?
134 # Memory capacity 30KB?80?/128programs?
135 # Memory capacity 4000KB?10240?/4000programs?
136 # Memory capacity 500KB?1280?/1000programs?
137 # Memory capacity 60KB?160?/200programs?
138 # Memory capacity 8000KB?20480?/4000programs?
139 # Memory-type pitch error compensation
140 # Memory-type relative position error compensation
141 # Mirror image by external input
142 # Mirror image by parameter setting
143 # Mirror image for facing tool posts
144 # MITSUBISHI CNC special format(FS15 drilling)
145 # Mixed control (cross axis control)
146 # Modbus Interface
147 # MORISEIKI special function 1
148 # Moveable range clamp
149 # Multiple-step optional block skip?for MORI SEIKI?
150 # Multiple-step skip
151 # NC data sampling (External input)
152 # Normal line control
153 # Number of tool compensation sets (400sets?
154 # Number of tool compensation sets?200sets?
155 # Number of tool compensation sets?40sets?
156 # Number of tool compensation sets?999sets?
157 # Number of tool life management sets (1000sets)
158 # Number of tool life management sets (400sets)
159 # Number of tool life management sets (600sets)
160 # Number of tool life management sets (800sets)
161 # NURBS interpolation
162 # OMR?
163 # OMR-FF
164 # Optimal time constant determination
165 # Optimum acceleration/deceleration selection
166 # Oscillation
167 # Pallet program registeration
168 # Parameter input by program
169 # Pecking tapping cycle
170 # Playback
171 # PLC axis control
172 # PLC axis indexing
173 # PLC interruption
174 # PLC protect
175 # PLC protection (Password)
176 # PLC skip
177 # PLC switch 64 points
178 # PLC window
179 # Pocket machining
180 # Polar coordinate command
181 # Polar coordinate interpolation
182 # Polish
183 # Portuguese
184 # Position switch addition(24 points)
185 # Position switching Reserved for point expansion
186 # Program restart
187 # Range signal
188 # Rapid traverse constant inclination multi-step acceleration/deceleration
189 # Remote program input
190 # Re-thread cutting
191 # Rotary axis workpiece position compensation
192 # Rotary axis workpiece position compensation?G54.2P1?
193 # Russian
194 # Safety observation
195 # Scaling
196 # simple programming
197 # Skip
198 # Skip retract
199 # Spanish
200 # Special fixed cycle
201 # Speed change skip
202 # Spindle speed variation control
203 # Spindle synchronization I/II
204 # Spindle temperature compensation?for MORI SEIKI)
205 # Spiral/Conical interpolation
206 # Spline interpolation
207 # SSS control
208 # Staggering thread cutting
209 # Start point designation timing synchronization
210 # Stored stroke limit 1B
211 # Stored stroke limit 1C
212 # Stored stroke limit 2B
213 # Stored stroke limit for orthogonalization coordinates
214 # Stroke check befor travel
215 # Swedish
216 # Synchronized tapping
217 # Synchronous control (M/L)
218 # T code mirror image for facing tool posts
219 # Thread cutting (Lead/Thread number of designation)
220 # Thread cutting cycle retract
221 # Thread cutting override
222 # Tool center point control?G43.4?G43.5?
223 # Tool compensation for additional axes
224 # Tool escape and return
225 # Tool function (designation with tool name)
226 # Tool geometry offset (Type 1)?for MORI SEIKI?
227 # Tool handle feed & interruption
228 # Tool ID, Tool IC
229 # Tool length compensation along the tool axis
230 # Tool life management?/?
231 # Tool posts interference check
232 # Tool presetter repeat?for MORI SEIKI?
233 # Tool retract
234 # Tool retract and return 2
235 # Tool spindle synchronization ?A?Spindle-Spindle ?
236 # Tool spindle synchronization ?B?Spindle-Spindle ?
237 # Tool spindle synchronization ?C?Spindle-NC axis?Polygon?
238 # Tool-SP synchronization II (Hobing)
239 # Turkish
240 # Turning tool offset for machining center system
241 # Two-way pitch error compensation
242 # Unidirectional positioning
243 # User macro
244 # Variable backlash compenstion
245 # Variable command ?200sets, 100+100)
246 # Variable command ?300sets, 100+200)
247 # Variable command ?600sets, 100+500)
248 # Variable command ?700sets, 100+600)
249 # Variable feed thread cutting
250 # Variable full closed twist compensate function
251 # Variable lost motion compensation
252 # Verification stop
253 # Workpiece coordinate offset measurement
254 # Workpiece coordinate system preset?G92.1?
255 # Workpiece installation error compensation
256 # Workpiece installation error compensation?G54.4?
257 # Workpiece position measurement
258 # ?????????
259 # ?????
260 # ?????????????
261 # ?????????????????????????
262 # ????????????????????
263 # ??????
