Programming an angle using sub-program
Results 1 to 6 of 6
Thread: Programming an angle using sub-program
    Member pb2304's Avatar
    Jan 2022
    Default Programming an angle using sub-program
    I have a Mazak vtc-300c here using mazatrol and I am trying to program a 1.5degree angle over 50mm. As follows my program is
    UNIT 1
    MANU PRO FACEMILL 63
    G0 G40 X-60. Y-6.5 Z100. M3
    G0 Z10.
    G1 Z0. F500.
    UNIT 2
    SUB PRO 22E REPEAT 72
    END
    SUB PROGRAM IS:
    G91
    Y-.35 Z-.009 F6000.
    X120.
    Y-.35 Z-.009
    X-120
    G90
    M99
    Now the sub program as it stands runs smoothly across the y z etc. Its the start point thats the issue, as shown I bring the cutter down to Z0. When it moves onto the sub program, the position changes and the Z moves to Z+150.141 and the the sub program begins from there.
    There is nothing in the program that I can see that would cause it to move there. Not been on this machine long so unsure of what I'm missing?
    thanks
    Apr 2013
    France
    Default Re: Programming an angle using sub-program
    There is no G54, G55.., nor tool call in this program. Maybe that's the cause.
    Jun 2010
    You should NOT have the G91 in the subprogram. Never (unless you really know what you are doing).
    You could put it at the start of the main program.
    Cheers
    Roger
    Jan 2022
    The manu pro 63 is a tool call. The g54 came before unit 1, only added in what i felt was relevant.
    Jan 2022
    Took out the unit 1, created a separate sub program to be called in first to bring tool to position and it worked fine. I worked with siemens controls for 14 years before moving jobs and always had G91 at the start of sub programs, same as the fanuc I'm also using in my new job, I've used G91 at the start of sub programs as its an increment movement. Out of curiosity why should G91's not be used?
    Jun 2018
    on my feet
    Quote Originally Posted by pb2304 View Post
    no reason why it can't or shouldn't be
