Hi everybody.
I am currently working with a Mazak FJV-250-Mazak Fushion 640M cnc milling machine. The machine's memory has a very low free space of 2.5M. Does anyone know how to install the machine to run the program directly on the memory card? ADAPTER no.help me.than
Boy, 2.5 Megabytes is a lot however if you want to 3D machine and it is not enough. Why dont you call tech support from Connecticut they should able to help you which parameter need to turn on.
C?m ?n.tôi ?ã g?i và h? c?ng ch?a tìm ???c gi?i pháp c? th? vì ??i máy là quá th?p.
