Mazak VCN-510 Matrix Control NO READY
Results 1 to 3 of 3
Thread: Mazak VCN-510 Matrix Control NO READY
    Mar 2016
    Default Mazak VCN-510 Matrix Control NO READY
    Hello
    Machine was off for a while. After swithed on "no alarms" but it didn't pull READY status. On servo amps. sais like "b1" "b2" "b4".
    External contactor is OFF state. So charge LED is off, if manually push contactor charge lamp is on state and power supplied to servo amp, but nothing happen still NO READY.
    How I understand driver not receiving ready on signal from NC. But what should avoid that signal?
    Mar 2016
    Default Re: Mazak VCN-510 Matrix Control NO READY
    And found little "o" symbol on power source module. Some how there no error like that in datasheet about that.
    Mar 2016
    We fix it, issue was brain board in power supply unit. it has some internal soft problem.
