Mazak multiplex with mazatrol t plus control. cicle start dont work.
Good afternoon, I have a mazak multiplex 6200 machine with mazatrol t plus etching. The machine is also equipped with a flex gl 100c robot loader. The problem is this. The machine settles down to zero points, it works perfectly in manual mode, it also works perfectly in MDI. But it does not always work in automatic mode. Sometimes it works sometimes not. You can turn it on and it will immediately start working as it should, or it can stand for a day and what buttons do not press, it just stands. There are no mistakes, no sounds, just waiting. I know that everything is like a robot, since it turns on and off. some nutritional problem. On the robot's board, instead of 5 volts 4.5 and instead of 15 volts 14.5. Tell me in what direction are they moving?
