Need Help! Citizen M32 Meldas 600 zero return
Results 1 to 3 of 3
Thread: Citizen M32 Meldas 600 zero return
    Member Drisscn's Avatar
    Jul 2019
    Default Citizen M32 Meldas 600 zero return
    Friends, I'm fine I hope you are doing well I have a problem with the machine a Mitsubishi m32 m600 at the turret level when I make the origins of the axes and the turret after I turn off the machine and I turn on the machine it loses its position each time I restart the machine it is necessary to make the origin of the turret
    Member h65's Avatar
    Apr 2021
    Default Re: Citizen M32 Meldas 600 zero return
    Normally, a M32 with a 600 control, after the first time that you homed all axis, the cnc should retain position after shut down, when you power back up, all you need to do is retract the turret and go to the start position screen, hit start and all axis will go to their start positions, if not, a parameter or two is not set right or something on the electrical side is wrong, but with the electrical side you will get a alarm.
    Jul 2019
    Exactly all the axes are perfectly at the origin but if right there Turret is after opening the encoder I found that the coupling Between the encoder and the motor and defective after rules that now when I turn on the machine there is Emg there is nothing that is engaged
    Attached Thumbnails Attached Thumbnails Citizen M32 Meldas 600  zero return-d80464d2-0aba-4eaa-bcd7-ed0e674473e1-jpg
