Need Help! Mazak Mazatrol 640T Parameter Error 26 after replacing battery spindle
Results 1 to 4 of 4
Thread: Mazak Mazatrol 640T Parameter Error 26 after replacing battery spindle
    Default Mazak Mazatrol 640T Parameter Error 26 after replacing battery spindle
    Hello,
    Can anyone please help.
    First problem was that the battery had to be replaced. This was done with an original battery of the vendor. Now the machin is starting. On the main panel the red light Alarm is showin. The Windows OS is booting but when the mazatrol software open you only can see the red error "Parameter error 26".
    Can anyone help ?
    Best regards
    Gernot
    Member Stanko1133's Avatar
    May 2019
    Default Re: Mazak Mazatrol 640T Parameter Error 26 after replacing battery spindle
    Hallo, please give your mailadresse so I can contact you.
    Gesendet von meinem SM-N950F mit Tapatalk
    Member Arni89's Avatar
    Nov 2020
    Hey, i'm sorry. Can anyone help me? After replacing the batteries, the spindle does not want to accept the replacement numbers.
    May 2019
    Quote Originally Posted by Arni89 View Post
    Was ist das Problem gib eine mailadresse
