Mazak H400 M32 Variation at Y axis
Results 1 to 2 of 2
Thread: Mazak H400 M32 Variation at Y axis
    Meka1292's Avatar
    Mar 2020
    Default Mazak H400 M32 Variation at Y axis
    Hello, we have a problem with a horizontal mill Mazak H400 M32 control.
    When machining a circle, X axis machining is correct, meanwhile Y axis has 0.07 inches less of cut.
    Did someone know if i can modify a parameter to adjust this difference?
    Or by the other hand, some one has the parameter manual?
    Sep 2012
    Default Re: Mazak H400 M32 Variation at Y axis
    Quote Originally Posted by Meka1292 View Post
    For that amount of variation i would be looking at a mechanical issue or maybe an encoder drive issue before trying to change backlash parameters
    Regards Bob
