I have a nomura lathe with the meldas control . When ever I try to home it out the y axis hits the emergency stop and kills the machine. I tried to adjust the soft limits but nothing works. Could it be a hardware issue? I changed the proximity switch thinking it might be bad but again same result
- Need Help!- MACH3 SOFT LIMITS – Main screen soft limit button will not illuminate
- Mach 3 - "Software Limits" Can't turn off Soft Limits
- Soft Limits not responding
- Need help 1983 mazak qt20 T1 control some pendant buttons soft keys not responding
- Need Help!- Setting up Config >Homing/Limits Dialog (Motor Home/Soft Limits)
Any alarms occur on the machine other than emergency.. Whats the 7seg status on all drivesI have a nomura lathe with the meldas control . When ever I try to home it out the y axis hits the emergency stop and kills the machine. I tried to adjust the soft limits but nothing works. Could it be a hardware issue? I changed the proximity switch thinking it might be bad but again same result
