Dear Sirs,
After transportation to another place have trouble with APC.
331 PALLET LOAD\UNLD DRIVER ALARM
on MR-J2-CT on LOAD Z70 0002 ABS/ reference point disappearance.
Test mode - Illegality.
Tried to fix by "ABS Pos. Repair" after system restart, the same alarm.
What is wrong and how to fix it?
Will be grateful for any help!
- Need Help!- mazak fusion 640m 4th axis rotation limit
- Need Help!- Mazak FJV250 with 640M Control
- Need Help!- Mazatrol Fusion 640M, Alarm 249
- Need Help!- Mazak Mazatrol Fusion 640m- FH6000 - Alarm 391
- 1999 Mazak FJV-250 with Fusion 640M Control
The battery voltage okay. I will try. Thank you for advice.
Lol: First check battery. If its good, then off on the machine, to get the drive into zero lost mode. Then setup zero point using MRJ2SW(u need to know where is your electrical zero and how to setup using MRJ2SW). Thats all.
