Hello, we have Mazak Integrex 70 turning and milling in production, the problem is that when programming it is necessary to put a point after the water drop after the coordinate value. That is, when you enter x100, the machine will go 0.1 along the X axis, and when you enter x100. will go 100 on the x axis. Please tell me how you can change so that with the x100 water the machine goes 100 mm along the X axis. Thanks
