Add M6
Sent from my D5803 using Tapatalk
Hello everyone, please help, machine mazak integrex 70.Control system Mazatrol T plus. Cannot perform tool change. Who knows how to write a tool change command correctly? In MDI mode, enter T0101, there is no reaction. Help me please
- Mazak Integrex 70
- Mazak Integrex 200 SY
- Need Help!- mazak integrex 200-ii sy
- Need Help!- Mazak Integrex 35
- Need Help!- Mazak Integrex 200 IV
Add M6
Does not react at all, the very fact that he read the command, and did not work. And you do not know, do you have to drive yourself to the tool change point? or is he himself? The machine does not even move, only the coordinates blinked on the counter, as if it had worked for something, but in fact, nothing happened.
Try T000t0m6, second t is to preload next tool.
Does it work in auto mode?
Call mazak
Hello,
Is there a tool inside the electrospindle ? if yes then,
T1xx is the command for unloading the tool, where T1 is electrospindle number and xx is the tool number.
Example:
ISO = T101M6 tool 1 loading demand from the spindle1.
ISO = T116M6 tool 16 loading demand from the spindle1.
Also you need to check the inputs from the spindle like, tool lock/unlock, tool present/abscent, tool sensor on magazine. Does it shows any error on screen ?
regards.
Did you check for sensor inputs ? And any errors on screen ?
I havent worked on this machine but in order for machine to know which tool is where, or if the tool is present on the holder/tool carriage/spindle there are sensors which send signals to the PLC (Programmable Logic Controller) so that when present/or absent (which ever is required) the machine does the further work. But when the required signal is absent the machine stops and (if programmed) give certain errors.
Thank you all, the problem has gone away to the decisions of the correct syntax for programming a tool call, namely T9000.8, which corresponds to tool number 9 in horizontal mode.
