Need Help! Mazak Integrex 70 - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 14 of 14
Thread: Mazak Integrex 70
  1. #13
    Member coc9's Avatar
    Jul 2018
    Default Re: Mazak Integrex 70
    I havent worked on this machine but in order for machine to know which tool is where, or if the tool is present on the holder/tool carriage/spindle there are sensors which send signals to the PLC (Programmable Logic Controller) so that when present/or absent (which ever is required) the machine does the further work. But when the required signal is absent the machine stops and (if programmed) give certain errors.
  2. #14
    Member endaeron's Avatar
    Jul 2019
    Thank you all, the problem has gone away to the decisions of the correct syntax for programming a tool call, namely T9000.8, which corresponds to tool number 9 in horizontal mode.
Mazak Integrex 70
Mazak Integrex 70
Mazak Integrex 70
