I have an older SuperMAX mill with a Mitsubishi MELDAS M3A/L3A controller and I am trying to locate a manual.
Current issue I am experiencing is giving me two codes:
Operational: M01 OPERATION ERROR 0006
Stop Code: T02 FEED HOLD 0201
If the codes mean the same thing as they do for an M50 controller I believe the problem has to do with my X-Axis limit switch (probably needs to be replaced). Suspected because I frequently am having to us the OT Release button to move the table in the X-Axis away from home. Admittedly I could be wrong, I'm no expert.
Battery has never been changed (as far as I know)... Is it possible OT parameters are being corrupted because of low battery?
