Mitsubishi Meldas 600M control won't run G83 peck drill cycle
Hello all,
recently the battery that provides power for memory when the machine is powered down died. I got that fixed but I must have lost parameter data because when I run a drill program with G83 it will not peck it just bores. My program is correct because I tried using a program that worked before the battery problem.
So my question is what parameter needs to be changed for the G83 cycle to work?
