Need Help! VTC-20B M-Plus no start
Results 1 to 15 of 15
Thread: VTC-20B M-Plus no start
    Mar 2011
    Sweden
    Default VTC-20B M-Plus no start
    having issue with my VTC-20B, it wont start. i have 230v to QX086 but no leds are lit (fuses are ok).
    Is there anything i can check/do or will i need to replace QX086?
    Sep 2017
    Bahrain
    Default Re: VTC-20B M-Plus no start
    When you pull out the QX086 card from slot and then power on, are the leds getting on ?
    Mar 2011
    Sweden
    Quote Originally Posted by navinbhas View Post
    Thanks for reply, forgive my ignorance but will i loose parameters by pulling the card?
    Sep 2012
    Check the 24v power supply
    Regards Bob
    Sep 2017
    Bahrain
    The process I said above will take less than a minute to check. Your data should be ok if the existing battery voltage is ok.
    The data is store in the S-RAM card mounted on QX141/QX161 and has a super capacitor which is capable of giving necessary backup charge. So make sure all is ready.. Pull out the card. Power on and then check if its powering on. Turn off and then plug in..
    Next step would be to remove all the output wire connections from QX086. Provide only the input supply and check if powering on or not. Check this step in both condition, QX086 mounted in the slot and taken out from slot/
    Mar 2011
    Sweden
    QX086 does not power on in any of the cases described above,
    I assume that the others cards next to it (QX141/QX521/QX539) does not power on because they are supposed to get power from QX086?
  7. #7
    Mar 2011
    Sweden
    anything else i can check?
  8. #8
    Sep 2012
    Quote Originally Posted by gusf View Post
    Have you checked the 24v supply
    Regards Bob
  9. #9
    Mar 2011
    Sweden
    Quote Originally Posted by sudsy View Post
    I just checked and 24v power supply is functioning
  10. #10
    Sep 2012
    You might need to do a re-initialise then reload all your parameters
    Regards Bob
  11. #11
    Mar 2011
    Sweden
    Is there any way to extract the parameters from the memory before? I dont have a digital copy of the parameters
  12. #12
    Sep 2012
    Not that I know of if the machine doesn't power up at all but someone else may know. There is a procedure after you do the re-initialise that will extract them from the ROM or RAM.
    VTC-20B M-Plus no start-re-initialise-t32-mc116-pdf
    Regards Bob
  13. #13
    Mar 2011
    Sweden
    I had a mazak tech checking the machine yesterday and he says the card is toast. I just ordered a replacement card
  14. #14
    Mar 2011
    Sweden
    The replacement card arrived on friday and now everything works. thanks for you help guys!
  15. #15
    Sep 2017
    Bahrain
    Hi gusf... Glad to hear the machine is ready.. Sorry was on travel, hence been offline for more than a month now.
