Need Help! Spindle Head not aligned with ATC
Results 1 to 2 of 2
Thread: Spindle Head not aligned with ATC
    Activation process Xprez's Avatar
    Oct 2018
    Default Spindle Head not aligned with ATC
    Leadwell VMC-25 with Meldas M50 Controller
    The Spindle Head on Z axis (runs various drills) jammed up against the ATC when it went to change tools - this was a few days ago and have been troubleshooting since. Unjamming it, releasing the tool and returning to zero isn't a problem. Machine was operating correctly prior to this and we havn't changed any parameters or physical locations.
    Restarted a few times, re-homed ect and machine appears to work normally (have full movement across X,Y,Z axis) BUT after first drilling operation Spindle Head moves back up to get into position for the ATC, moves across and jams/fouls against the ATC - so the issue persists.
    On visual inspection of the Spindle head relative to the ATC the Spindle Head appears to be approx 6mm higher than where it should be to align correctly with the tools on the ATC.
    The recent alarm history:
    Operation Errors
    0101
    0004 Z
    Stop Code
    0203
    3.ATC Not Ready
    Have taken following actions:
    ATC recover mode in PLC-SW - no change
    #2038 (#2_rfp) Second Reference Point from zero for Z axis. Amendments to values made no difference to Z position of Spindle Head when it went back to zero unfortunately
    Havn't fiddled with #3207 (SP001, OPST) for Spindle Orient position shift. My understanding is this changes degress of rotation of Spindle head but this doesn't appear the cause of the jam, it seems height related
    Without knowing the root cause of the misalignment it seems I may need to set a new zero coordinate on Z axis to compensate.
    Advice and input greatly appreciated.
    jgsak's Avatar
    Oct 2018
    sorry can't help, have a atc issue also on a meldar 520 control, spindle comes to position on tool change, spindle stops, but does not align, and spindle just rotates slightly back, and you can spin spindle by hand,with no resistance. no alarm
