Engraving Numbers
Results 1 to 9 of 9
Thread: Engraving Numbers
    Registered D.E.L's Avatar
    Sep 2013
    Default Engraving Numbers
    Any help/suggestions on how to program number engraving?
    Im guessing it will be a manual program.
    Would be interested to know if numbers can be programmed using an endmill tool suitable.
    Numbers in question would be:
    • 0
    • 1
    • 2
    • 3
    Thanks in advance.
    Gold Member Jim Dawson's Avatar
    Dec 2013
    Default Re: Engraving Numbers
    Create the text you want in any CAD or most CAM programs and just post process the text as normal G code. Most CAD or CAM programs have a text function that will generate any printable character. You could code it by hand also, but it's easier in software. You can use any suitable end mill or engraving bit depending on the size of the text.
    Jim Dawson
    Sandy, Oregon, USA
    Sep 2013
    Thumbs up Re: Engraving Numbers
    Quote Originally Posted by Jim Dawson View Post
    Hi Jim.
    Thanks for your quick reply.
    Unfortunately I do not have any CAD or CAM software.
    I will have to try and find something to do this.
    Thank you for your advice, much appreciated.
    Dec 2013
    How do you normally program your machines? You could draw the numbers on graph paper and manually generate the G code from that.
    Jim Dawson
    Sandy, Oregon, USA
    Apr 2016
    what kind of machine are you using?, i can code the numbers for you if its just the g code you want?
    Registered mark-s's Avatar
    Apr 2017
    End mill to use, depends on the size of the lettering.
    I use 1/16-1/8- 3/16-1/4 inch down cut end mills.
    mark-s
  7. #7
    Apr 2016
    i like to use a harvey engraving tool
  8. #8
    Sep 2013
    Hi folks....
    Programming is done in front of the machine.
    Mazatrol units or Manual units.
    CAD or CAM is never used.
    We are Metric parameters.
    Machine control is - Mazatrol Fusion 640M
    Any ideas how i can program the following numbers using metric dimensions:-
    1
    2
    3
    Thanks in advance.
  9. #9
    Dec 2013
    Quote Originally Posted by D.E.L View Post
    Hi folks....
    1
    2
    3
    Thanks in advance.
    You could draw the numbers on graph paper and manually generate the G code from that. It's possible to generate the numbers with only G1 moves.
    Jim Dawson
    Sandy, Oregon, USA
Engraving Numbers
Engraving Numbers
