1998 Mazak Quick Turn 25L with Mazatrol T Plus.
It appears presently only Mazatrol enabled programming and automatic cycle. Searched screen, bottom row of functions and tabs and no EIA/ISO programming. Could Parameter tab have a bit to enable EIA/ISO programming? Located P16 and bit 3 of 1 which, appears enabled EIA but no EIA tab to switch to page yet. Are any other Parameters required to enable EIA program and switch to it's page, if is, which one's?
Mazak Program and Parameter Manual indicates Mazatrol T Plus includes EIA/ISO programming. Located other Parameter EIA bit's in the Manual but haven't checked if disabled or enabled yet. Considering enabling all EIA bit's to see results. Could EIA program be an option to install with machine from a Distributor and Service Technician and requirement regardless the already stored bit's?
It might be Mazatrol program to EIA/ISO Converter tab to get G code program and without Tape. Yet this tab doesn't appear available with particular control.
