I'd like to know if I should leave the Floppy Disk BND-212W001-B1 in the Mill all the time?? It usually stays in there but I've recently had to replace the battery and not sure if the floppy will get damaged/compromised if left in the mill continuously..Thanx in advance
If the system disk loads every time you power on, then you need to leave the disk in. If you want to have the disk out, then you need to make sure the large motorcycle battery is good.
