Same part program different pallet? HCN5K
Results 1 to 1 of 1
Thread: Same part program different pallet? HCN5K
    Jul 2007
    US of A
    Default Same part program different pallet? HCN5K
    We want to run the same part program on multiple pallets. What methods work well to do this. I don't want to have a unique part program for each location, our current program structure is Pallet prog>Part prog. The pallet prog calls the part prog, part program contains all machining information for operation, as well as additional sub programs needed for operation.
    Matrix Nexus control type,
    Palletch system for the pallet pool
    Mazatrol with EIA nested.
    For now I am the program structure I will use is
    Main prog>WPC, MMS, SUB-PROG, PART PROG
    So the Main prog is associated to a specific pallet and calls up the "positioning" part prog, the pos.prog has part zero info and calls up "machining" part prog
    Suggestion and concepts are appreciated
