Hello everyone
At work recently brought a Lagun mill with a Heidenhain TNC310 controller.It is our 1st CNC so we are learn as we go. We are able to move the X,Y and Z in manual mode but we cant turn the spindle on Does there need to be tool in the collett for this to work or is there a command that we are missing.
Also is the datum stored when you turn the machine off. What is the easiest way to keep the datum in a certain place. We have read the manual but this doesn't seem to hold.
Any help would be appreciated
Thanks you
Gareth
- Bridgeport Series 2 Interact 4 parts and Granite Devices servo driver boards. Incl. Heidenhain TNC 155, Bosch servo drivers, Heidenhain handwheel encoder, Granite Devices VSD-XE - No Longer Available
- Interesting troubleshooting RE: Heidenhain TNC310
- Heidenhain
- Heidenhain 150 help
- Heidenhain TNC310 RS232
Anyway U should first input spindle speed data. In manual there is S softkey after presing it U can set the speed and confirm it with cycle start, NOT ENTER.
Also in MDI u can write toolcall withn no values beside S parameter (which sest spindle speed) and in next line M3/M4.
Tool is no needed to turn on the spindle.
