Need Help! Mazak T1 zero return help
Results 1 to 12 of 12
Thread: Mazak T1 zero return help
    Member ChrisW's Avatar
    May 2003
    Lake In The Hills
    Default Mazak T1 zero return help
    Hello
    Can anyone help me get this machine going.
    I can zero return axis but I get these ALARMS. See picture
    Attached Thumbnails Attached Thumbnails Mazak T1 zero return help-uploadfromtaptalk1375326352973-jpg   Mazak T1 zero return help-uploadfromtaptalk1375326290049-jpg
    Registered MrMazak's Avatar
    Dec 2007
    First off, put some numbers in the tool data to get rid of the stars. The machine is over traveled in both axis. Move them minus with the hand wheel while pushing in the over travel release button. (blue push button) Make sure them way lube tank is full. Pump it by hand by pulling the plunger up 3 or 4 times to prime the system. Nothing is going to move until the lube alarm is cleared. If that doesn't work let me know. I live by LITH and could stop by.
    May 2003
    Lake In The Hills
    Mrmazak.
    I can't send you pm.
    Dec 2003
    Check the parameter screen, if you have asterisks in any of these, you need to reload all parameters.
    Hopefully you have them?
    May 2003
    Lake In The Hills
    Quote Originally Posted by Al_The_Man View Post
    There may be some with asterisk
    I checked most of them are not used by control
    Most have numbers
    I have no backup of parameters.
    To verify they are correct
    Dec 2003
    I have some for an SL-40 that may help.
    Write down the ones you have first.
    The OP para have to be entered with a 9 digit that includes parity number for e.g. OPx 010001013
    Attached Thumbnails Attached Thumbnails Mazak T1 zero return help-t1initialize-pdf   Mazak T1 zero return help-t1par-pdf   Mazak T1 zero return help-t1pardef-pdf
    Jul 2010
    Ireland
    How to clear asterisks on T1. You will need to take note of parameters first.
    to clear all rubbush on T1
    Press MENU key. Press Param. press PAGE, bring cursor to OP12, press
    111111118 IMPUT
    Power off/on
    To clear tool data
    Press MENU key
    Press T-Data
    Press 8th button from left
    press CLEAR key
    To clear "Tool set"
    Press menu key
    Press T-SET
    Press 9th key from left
    Press CLEAR key
    To clear cutting conditions
    Press MENU key
    Press C-COND
    Press 9th button from left
    Press CLEAR key
    To clear "Programme"
    Press MENU
    press PROG
    press ALL ERASE
    press INPUT
    To clear parameters
    press MENU key
    press PARAM
    press 8th button from left
    press CLEAR key
    press PAGE menu
    press 8th key
    press CLEAR key
    To load all information
    bring cursor to A7
    press 16 then INPUT to set baud rate
    bring cursor to OP2 and press
    000000101 then INPUT (to set CMT available
    Power off/on
    If you have CMT or micro disk or Griffo with info on it, connect to machine.
    Press MENU
    press DATA IN OUT
    press DATA IN
    press 123456
    press INPUT
    the CMT will load all information
    otherwise you will have to load it manually.
    to load parameters OP1/16, there are 8 digits 0 or 1, if there are 2 "1" on line type 2 as 9th digit etc
  8. #8
    Aug 2014
    Default Re: Mazak T1 zero return help
    Hello,
    I'm having the same problem ... 4 years without electricity!
    Is your mazak with Mazatrol T1 running back?
    Yours sincerely
    Frederik form belgium
  9. #9
    *Registered User* truongkma's Avatar
    Jul 2018
    You have manual on t1 machine. can you give me?
    Thank u very much
  10. #10
    Member Smott's Avatar
    Oct 2019
    Can anyone tell me how to clear a deceleration sensor malfunction? It comes up every time I trip to use the auto measure on my nexus 750.
  11. #11
    May 2018
    do you EIA or mazatrol?
    can help me with post processor?
    - - - Updated - - -
    does mazak have a way to set up a LIMIT so you will not over travel in Z minus? for example to avoid crashing into the chuck?
  12. #12
    Jul 2010
    Ireland
    There are barrier settings on tool set page, but still cannot guarantee that you wont crash, long jaws boring tools etc. Check 1st off at low rapid rate.
