I have never seen that one, but the info I have says that editing and I/O cannot be continued and to contact Mitsubishi service and give the classification number of the error (18).
Does it occur on program editing or download?
My book is not too clear as to what I need to do with this error. Does anyone have any suggestions?
Seems to be a file saving issue. Do you know how to reformat?
I have had similar cryptic messages to contact Mitsubishi and it has turned out to be a defective eprom, identified by the classification number, and they sent out a new set for installation. Do you have the number for Mits. Chicago, you can usually get some one rightaway, (Unlike Fanuc!!).
When I zero out the X,Y and Z axis, I am not able to move them after they reach their home positions. Do I need to enter in the data somewhere? Presently I select Zero Home and push each axis button. All three home buttons light up, then I can do no more.
Sounds like the soft limit parameters need to be re-set. You can check these in the process parameters.
To reformat the program memory:
Go into the machine parameters. Let me know if you need instructions on doing this.
Set parameter 1166 fix_p to 1
Go to the program erase page. Type the word 'FORMAT' in the second set of brackets and press <input>. Like this:
( )(FORMAT )( )
The control will respond with 'ERASE COMPLETE'.
Go to the Input page and type the number 4 into the first set of brackets:
(4)( )( )
Press <input> and the control will load in the canned cycles.
Turn the control off and back on again.
Just wanted to touch base and say thanks to everyone. I am now working on the DNC using the free one that is talked of. That's today's project.
Thanks Again
David
