Need Help! Setting Mazak Measuring Unit.
Results 1 to 5 of 5
Thread: Setting Mazak Measuring Unit.
    Registered EliseoMonteverd's Avatar
    Dec 2007
    Uruguay
    Default Setting Mazak Measuring Unit.
    Machine : Mazak VQC 15/40
    Control : M 32
    YOM :1990
    I was overhauling the measuring unit (change taper bearings,coil, and magnetic sensor), and doing some conection, because the previos owner has disabled it.
    After some tests, I noticed that a tool of 72.00 mm (2.830") long, the machine takes 720.00 mm (28.30") long on the tool data page.
    I don't know why the real length of the tool value is multiplied by 10. Is a parameter wrong?
    Thanks in advance.
    Member CNCRim's Avatar
    Feb 2006
    have you try to contact Mazak? I have tooleye calibration for lathe only sorry.
    Mar 2005
    Silicon Valley, CA
    I don't think the Tool Eye is multiplying by 10 ..... I think you just need to adjust your R parameter for the Z axis to adjust the Tool Eye...
    It's just a part..... cutter still goes round and round....
    Jul 2009
    UK
    Default Hope this helps
    Not sure of the parameter.
    Tool length data is stored in #vars #60001 and up (ie tool 1) on our machine.
    If its always a factor of ten add the following line to your programs, after the tool measure.
    #6000n=#6000n/10
    Where n is tool no
    Jan 2010
    Denmark
    Default Re: Setting Mazak Measuring Unit.
    Quote Originally Posted by EliseoMonteverd View Post
    Control : M 32
    YOM :1990
    Thanks in advance.
    Hello can you tell me how to disable the tool measure unit? myne got a bad sensor.. and i never use it.. Its giving me an error and woule like to disable it to get the error gone.
    I got a VQC like yours
