Aluminum cleaning
Results 1 to 4 of 4
Thread: Aluminum cleaning
    B_Bachas's Avatar
    Jul 2019
    Default Aluminum cleaning
    Hello,
    looking for a best solution to clean laser cut aluminum parts. We have continuous orders for laser cut parts. Part size is approx 15 cm x 10 cm, it has several holes (diameter 8 mm). Batch is typical 200 - 400 pcs.
    Requirement for part finishing: "clean surface, no grease, no burrs, no sharp edges.
    Could you recommend what is the best method to make proper part finishing for such size batches?
    What is the best way to clean and degrease aluminum parts?
    thanks
    Dec 2013
    Default Re: Aluminum cleaning
    That finishing requirement is pretty much a standard notation on all drawings. If the customer is happy with the pieces as they come out of the laser then no further finishing is required.
    If not, then hand deburring and/or vibratory finishing might be required. Normally just some degreasing solution (liquid household cleaner) in the vibratory water is good enough. Another option for cleaning is a standard home dishwasher, I use mine for this all the time. There are commercial part cleaning systems, but for short runs it really makes no sense to spend that kind of money.
    Bottom line is that the customer sets the requirements.
    Jim Dawson
    Sandy, Oregon, USA
    Depending on the parts load there is a relatively inexpensive countertop residential dishwasher available. Set anywhere you have a sink and a countertop.
    Bob La Londe
    http://www.YumaBassMan.com
    We can use standard vibratory finishing process with plastic tumbling media cone 20mm (or 3/4 inches), the green colour XG recipe from Vibra Finish
    Tumbling time about 1-2 hours depends on your burr size
    More information: https://www.inovatecmachinery.com/po...aluminum-parts
    Earnest
Aluminum cleaning
Aluminum cleaning
