- Bead blasted Brown anodized aluminum shows every scuff and lint
So the color is great but if you run your finger across it a white scuff appears. Washing removes the scuff but this really shows the lint.
It looks best when wet as a flat deep brown.
Is there something I can rub on the parts to get this wet look?
Re: Bead blasted Brown anodized aluminum shows every scuff and lint
2 options.
Hard anodising is durable, most auto parts use it.
You will need to outsource this.
Clear-cote aka lacquer, may work depending on use.
- You may not post replies
- You may not edit your posts
Forum Rules
