- Wood CNC services required
Hi all,
I’m interested in manufacturing a wood product that will require some CNC work.
My aim is to use a wood that is quite lightweight and inexpensive that would be easy to sand down to a very smooth surface. The smooth finish is a must as the final product will be in touch with the skin so no splinters are a must.
We are looking to run a sample run for beginning and will move into production if the numbers are right.
Please get in touch and I will send you the files via email.
Any questions , fire away.
Kind Regards,
Florin
- You may not post replies
- You may not edit your posts
Forum Rules
