Excellent CNC Machining service
Results 1 to 1 of 1
Thread: Excellent CNC Machining service
    Member konwey's Avatar
    May 2017
    China
    Default Excellent CNC Machining service
    We are China machining parts, metal stamping parts, turning parts, cnc parts, Springs, cold forming parts, machining parts, screw machine parts, casting parts, forging parts supplier, We can produce machined parts according to your requirements.
    Machining parts: Hydraulic, Valve, Fange, Automobile, Shaft, Bearing Housing Bar, Plate, Welded Part, Marine Part, Winch Part, Sheet Metal.
    Equipment: Common lathe, CNC Machine, Milling, Turning, Stamping Machine, Spring Machine.
    Metal Process: CNC Machining,CNC Precision Machining,CNC Milling,CNC Drilling,CNC Turning,CNC Tapping,China CNC Machining Supplier.
    Surface Treatment: Zn (Cr3 RoHS free or Cr6 ) plated, Cr /Ni plated, Hot-dip galvanizing, Paint, Anodize, Powder coating, Brush, Polish.
    Technical: Dedicated mechanical designer, experienced worker 3D design service inclusive of modeling, analysis and detailed drawing at normal cost
    Quality: ISO 9001: 2008
    Control strictly and follow specification move fast to meet your urgent need caused by accident.
    Packing: Wooden case, Hardboard, Steel pallet, according to custom’s requirements.
    If you want to know more about machining parts in China, Please contact us.
    Excellent CNC Machining service-1-jpgExcellent CNC Machining service-2-jpgExcellent CNC Machining service-1-jpgExcellent CNC Machining service-1-jpgCnc Machining,Milling,Turning,Drilling, Planing,Cnc service Suppliers and Manufacturers at China
    Attached Thumbnails Attached Thumbnails Excellent CNC Machining service-1-jpg   Excellent CNC Machining service-2-jpg   Excellent CNC Machining service-1-jpg   Excellent CNC Machining service-1-jpg
    Over 15 year in cnc machining parts business.CNC Turning, Milling, Drilling, Planning, Grinding, Welding ./www.plusminusthree.com Email?kon@plusminusthree.com
