- the CNC lathe Manufacturing Solution Provider from Taiwan
We are the CNC lathe Manufacturing Solution Provider from Taiwan north"TE YUAN CO., LTD"(Certified ISO 9001)
We use the Citizen cincom CNC lathe Machine from Japan
Processing size:MAX 25mm
Materials:Iron,Stainless,Aluminum,Copper,POM&ABS Plastic
Heat treatment:tempering,bright heat treatment,thermal refining ,carburizing,oil quenching,salt bath
Surface Treatment: Anodize, Zn plated, Cr plated, Niplated,blackening
Services we offer:CNC turning and milling,Prototyping,Secondary processing
Send your drawing & Request for Quote Now
Hank@cnc.tw
- You may not post replies
- You may not edit your posts
Forum Rules
