We're a Stockist/Manufacturer of Aluminium Extrusions.
Our 15M/50ft bed for the 5 axis SBZ151 machine is one of the largest in the UK. We can extrude with our partner up to 500mm in diameter profiles. "Cortizo" in Spain.
Any bespoke projects are undertaken. We also have 2 saws, one of which is a Automatic saw that can cut down to 10mm in length.Also have another 3 CNC machines that are on the shop floor. Our warehouse can hold your stock up until you require your profiles to be delivered.
The packing and assembly branch of Vision Profiles can try to cater to your every need, to make life easier for you.
All in, We're the one stop shop for anything Aluminium Extrusion based.
Any questions, our in house technical team will try to answer your query's as soon as possible.
If you need a quote for a die extrusion or machining/assembly/kitting please phone or email. We're only to happy to help.
