Waterjet cutting machine and waterjet cutter EAAK
Results 1 to 2 of 2
Thread: Waterjet cutting machine and waterjet cutter EAAK
    Member sinowaterjet's Avatar
    Jul 2014
    China
    Thumbs up Waterjet cutting machine and waterjet cutter EAAK
    EAAK CNC waterjet cutter application:
    The cutting materials are not limited (such as stainless steel,carbon steel,copper,brass,aluminum and other metal,glass,stone,marble,granite,foam,ceramics,plastics,composite materials...), waterjet cutting is currently the most applicable cutting method;
    Metal cutting:
    1 Decoration of stainless steel,aluminum.iron,brass and other metal cutting process.
    2 Manufacture of machinery and equipment control cabinets such as food machinery,medical machinery,CNC machinery.
    3 The metal parts cutting such as stainlesssteel flange,semi-finished,steel construction, non-ferrous metal and so on.
    Glass cutting machine:
    1 Gas stove surfaces, range hood,disinfecting cabinet, TV, bathroom products.
    2 Construction and decoration glass,automotive glass.
    Ceramic and stone cutting:
    1 Ceramic cutting for decoration and construction.
    2 Marble mosaic,granite mosaicmstone plate cutting.
    Waterjet cutting machine and waterjet cutter EAAK-gantry-structure-water-jet-cutting-machine-ek4020
    Attached Thumbnails Attached Thumbnails Waterjet cutting machine and waterjet cutter EAAK-gantry-structure-water-jet-cutting-machine-ek4020
    Shandong EAAK Machinery Co., Ltd www.sinowaterjet.com
    Email: Jack@sinowaterjet.com Whatsapp:0086 130 2657 0308
    Jul 2014
    China
    Default Re: Waterjet cutting machine and waterjet cutter EAAK
    Specification of EAAK CNC water jet cutting machineas follows)
    Model EK2030
    X Y axis Working size 2000mm*3000mm
    Z working height 150mm
    Cutting Pressure 380Mpa 30kw UHP pump
    Control accuracy 0.01mm
    Cutting accuracy 0.1-0.2mm
    Repositioning Accuracy 0.05mm
    Max cutting thickness 300mm(depends on materials)
    Max. moving speed 6000mm/min
    Power supply 380V 50Hz
    Environmental temperature -10-50°C
    Max flow rate 3.7L/min
    Max oil discharge 206L/min
    Max delivery capacity of oil pump 106L/min
    Control system Ncstudio (Shanghai) software IPC controller
    CAD/CAM software AutoCAD,ArtCAM
    Drive motor Japan Yaskawa servo drive motor
