Sony Millman DRO, LH51-2 ... mounted on a Bridgeport, If I don't move the table, X axis, for a few minutes, The readout shows " ERROR" Any suggestions? Thanks in adance.Similar Threads: Omni 1350 Linear ATC Indexing problem on z axis problemNeed Help!- Fadal Idler problem. Rpm pulse problem Tube problem or powersupply problem? Help you to check out daewoo puma 12lb tape format problem/parameter problem Surface finish problem - Could you please help me overcome this problem?
View Tag Cloud
Forum Rules
