Where would I buy 5 degree or 6 degree carbide burs? I need to undercut the dogs on a motorcycle transmission.
- Snapping 1/8" endmills. Can Sprutcam remove burs?
- Need Help!- back side of hole with burs.
- .2490" Solid Carbide Reamer Custom Carbide Straight Flute #300-2490- NEW & CHEAP
- what do you use to cut off carbide drill bits and carbide endmills
- Sandvik Inserts - Carbide, Taps, and Carbide Twist Drills - New Items
