3 phase motor from Cincinatti #2 Tool and cutter grinder not working
Results 1 to 2 of 2
Thread: 3 phase motor from Cincinatti #2 Tool and cutter grinder not working
    Aug 2013
    Mexico
    Default 3 phase motor from Cincinatti #2 Tool and cutter grinder not working
    Hello Everyone,
    I purchased a Cincinatti #2 Tool and Cutter Grinder on Ebay and have just hooked
    it up...nothing.
    I checked first to determine that it was wired for Low Voltage 220 3 phase
    I am getting power to the motor as 206 volts to each leg. I live in Mexico so thats all we get here.
    I disconnected all 9 motor leads and checked the conductivity of each possible combination
    of leads 45 in total.
    8 of these combinations are closed and I believe that only 6 should be closed.
    Can anyone verify this or give me another test to determine if this Spindly Motor will
    need to be rewound?
    Best Regards,
    Preston
    Aug 2013
    Mexico
    Default Re: 3 phase motor from Cincinatti #2 Tool and cutter grinder not working
    Ok, found the problem...
    2-8 is open vs 1-4 and 3-6 have 7.1 ohms resistance.
    Best Regards,
    Preston
