Help: Fanuc Servo Battery 6V Dead
Results 1 to 6 of 6
Thread: Help: Fanuc Servo Battery 6V Dead
    *Registered User* Ali2571979's Avatar
    Jul 2018
    Post Help: Fanuc Servo Battery 6V Dead
    Hello Friends
    I use CNC Lathe machine Fanuc control 0imat-TF but unfortunately servo battery goes to dead. i replaced the battery but parameters are lost and the f
    following alarms are occurred.
    DS 0300 X axis need Ref return
    DS 0300 Z axis need Ref return
    Please anybody solve this problem.
    May 2016
    United Kingdom
    Default Re: Help: Fanuc Servo Battery 6V Dead
    If your machine is showing this alarm it has not lost its parameters it just needs re-referencing
    What machine is it
    Please anybody solve this problem.[/QUOTE]
    Jul 2018
    Thanks for guiding. The machine wants to reference but when i reference the machine the reference key is not working and the machine patrol lights (red,green,yellow) also not working.
    Jun 2007
    México
    Hello,
    I have a similar problem. I read a "1390 turret amp alarm" on a hwacheon lathe control FANUC 18T. I changed the battery. How do I re-reference my turret?
    May 2016
    United Kingdom
    I take it you mean the reference switch on the controller
    That is a red herring as machine needs to be calibrated to obtain a position from its zero
    What controller is it ? and what machine
    - - - Updated - - -
    Quote Originally Posted by brujo View Post
    Hello,
    look in parameters does it see the turret as an axis ?
    Jun 2007
    México
    Sorry about the late response.
    The machine is a Hwacheon Hi-ECO 21HS BB, the control is a FANUC 18T. The alarm displayed on the control is "1390 TURRET AMP ALARM" and on the servo amplifier (a06b-6093-h152) I get the "II" or 11 alarm.
    The 1390 alarm, according to what I could find online, means "TURRET TEST MODE".
    And the 11 or "II" alarm on the servoamp means: "When the absolute pulse encoder is used, the motor has not yet rotated through more than one turn after the first power up"
    My problem is that I cannot figure out how to rotate the turret!!
    Here is what I have tried so far:
    1- I enable WRITE MODE (change from 0 to 1)
    2- I go to the keep relay page and according to the manual:
    K0.0 set to 1= TURRET INDEX AT ZERO POSITION
    K0.1 set to 1= TURRET 1 POINT INDEXIONG MANUAL MODE
    (I have tried turning each one independently and combined)
    3- I go back to WRITE enable mode and turn back to "0"
    4- Press reset
    I should be able to uncamp the turret, the problem is HOW. And that is where I am stucked
  7. #7
    Member Pranav820's Avatar
    Aug 2022
    Hey I’m having the same issue now. Was there any resolution to this problem?
    4- Press reset
