Bondo Spoilboard Re-surfacing
Results 1 to 3 of 3
Thread: Bondo Spoilboard Re-surfacing
    Jan 2007
    Default Bondo Spoilboard Re-surfacing
    Wonder if anybody else has used bondo auto body filler to re-surface a worn spoilboard. I have done this several times now and am really happy with the result. I simply (and quickly) mix up so of the filler and slap it onto the spoilboard rough spots and let it cure. In minutes, you can flycut a new surface with ease. In the picture attached I am doing a bigger machine with a particle board spoilboard, but I have a small machine at home and it has a spoilboard made of solid surface countertop and the bondo re-finishes it as well. The bond seems to be great and it cuts like butter. Not too expensive either.
    Attached Thumbnails Attached Thumbnails Bondo Spoilboard Re-surfacing-bondospoilboard-jpg
    Dec 2013
    Default Re: Bondo Spoilboard Re-surfacing
    Never used Bondo on a spoil board, I just replace them. But there is Bondo patches in the plastic table overlay. Not from my mistakes, I bought the machine used. But it does work well.
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    I've used epoxy with lightweight filler for accidental deep gouges. Basically the same as bondo, but harder, and bonds better.
    UCCNC 2017 Screenset
