- Cutter recommendation
Does anyone have any recommendations for a milling cutter for roughing epoxy tooling board? I am after a cutter around 20-25mm diameter with a long shank length around 200-300mm. It can be an indexable insert cutter or solid.
Does anyone here who machines epoxy tooling board for composite mould patterns have any suggestions?
- You may not post replies
- You may not edit your posts
Forum Rules
