- Accident repair
Accident repair
I have got a cnc lathe slant bed of jyoti fanuc oi tf controller 2 axis.. the issue which I am facing is that few weeks back one of my employee crashed the machine and I have got the engineers and got the allignments fixed of head (spindle) -.110 in the length of 40mm, and z -.300... But the issue is still it gives taper of +0.025 in the length of 40 mm. It doesn't runs out... But it's taper fluctuates even at 0.5 depth of cut and if the cut is just 0.01 then it goes straight no taper at all. Earlier I could give depth of cut upto 5 mm, never faced any problem. Can't think of what could be the issue as it doesn't even makes any sound of breakdown.... Can anyone help..
As the company service people of jyoti isn't much of help just some bunch of lazyyy peps.
Re: Accident repair
Get yourself a decent engineer who should have checked that
- Accident repair
- You may not post replies
- You may not edit your posts
Forum Rules
