Will an iso30 scm toolholder work in a standard iso30 spindle?
Results 1 to 9 of 9
Thread: Will an iso30 scm toolholder work in a standard iso30 spindle?
    Feb 2013
    Default Will an iso30 scm toolholder work in a standard iso30 spindle?
    Hey everyone. I just bought an expensive aggregate head for my CNC with an hsd 915 atc spindle. To my horror, I realized that it is the toothed scm version of of the iso30 toolholder. Will an iso30 scm toolholder work in a standard iso30 spindle?
    Thank you. Troy.
    Member machinehop5's Avatar
    Aug 2009
    Default Re: Will an iso30 scm toolholder work in a standard iso30 spindle?
    ...this might help ya
    Machine Tool Shanks (Tapers)
    Feb 2013
    Thanks for this, I have been there already. Unfortunately they have no reference for the scm version of the iso30 geometry.
    Sent from my SM-G975W using Tapatalk
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Looks like they might work, but you'll need to try it and see. Depends where the teeth are in relation to the taper. I've never seen one in person, but looking at pics, it looks like the teeth are low enough.
    UCCNC 2017 Screenset
    Feb 2013
    Quote Originally Posted by ger21 View Post
    Hey ger21. I've been thinking the same. The head unit is shipping at the moment so as soon as it gets here I will experiment and post the results.
    Yeah those teeth on the scm/morbidelli holders look to be about the same thickness/depth as a standard iso30 holder.
    While the teeth factor is my biggest fear, I am also concerned about pullstud compatibility and also the notch deadcenter of the taper.
    I have drawn with a marker on my existing holder where the teeth and notch are on the scm version in case anyone else can offer some insight.
    Thanks ger21.
    Feb 2013
    Heres an image of the toolholder on the aggregate I ordered:
  7. #7
    Mar 2003
    Shelby Township
    The notch doesn't matter, but the pullstud does. You need the correct pullstud.
    Our Morbidelli uses HSK toolholders.
  8. #8
    Feb 2013
    Right - I need the hsd compliant pullstud. Do you know if the threading is the same?
  9. #9
    Mar 2003
    Shelby Township
    I think all pull studs have the same threads, but it's been 10+ years since I've used an ISO 30 machine. We used to get pull studs from Ghudo.
