- Need some guidance
Need some guidance
I have a Mitsubishi ML4020RX-F60 Fiber Laser Cutter and I have an issue that I cannot seem to figure out. To start with I am not really sure what the problem is but I have done everything I know to do to try and fix the issue, but no luck. This seems to really only be an issue when cutting stock 3/8" and thicker. The laser seems to cut just fine in 3 of the 4 directions but on one side the cut will be concave and will have slag stuck to the bottom of the sheet and part. I am attaching some photos of what I am seeing. I would really appreciate any help.
If you still haven't figured out what the problem is, I'd recommend that you contact customer support, if possible even send them an email with the photos and explain the situation.
- You may not post replies
- You may not edit your posts
Forum Rules
