HOW DO YOU METRIC THREAD WITH OKUMA LATHE OSP
Page 1 of 2 12 LastLast
Results 1 to 20 of 38
Thread: HOW DO YOU METRIC THREAD WITH OKUMA LATHE OSP
    Member okuma1984's Avatar
    Oct 2018
    TILSONBURGE
    Default HOW DO YOU METRIC THREAD WITH OKUMA LATHE OSP
    Hi there I am wondering if anyone knows how to set the machine in metric?? G20 to G21 ?? ? ? I know that's Fanuc but does Okuma work like that too? or do you convert to inches?
    I have done several threading jobs with this machine in inches however I am having a hard time writing Metric or converting it in Okuma
    so basically I am trying to 9MM x 1.25 pitch
    can anyone write a G71 line or tell me what to fill in the blanks in IGF?
    major diameter 9mm
    minor 7.647mm
    pitch 1.25mm
    Lead?
    TPI??
    X Start .38"
    X finish or minor diameter .301"
    H[eight of thread]: .0266 I believe ? (or 9 - 7.647 /2 in MM)
    that's all I got for now.
    thanks
    Attached Thumbnails Attached Thumbnails HOW DO YOU METRIC THREAD WITH OKUMA LATHE OSP-img-1989-jpg
    Dec 2013
    Default Re: HOW DO YOU METRIC THREAD WITH OKUMA LATHE OSP
    Convert pitch to Imperial
    1.25 / 25.4=0.0492
    Calc TPI
    1 / 0.0492=20.32
    The lead is 0.0492'', the TPI is 20.32
    Major dia = 0.354''
    0.866 is a constant for metric thread depth
    0.866*pitch = 0.866*1.25 = 1.0825mm = 0.0426'' thread depth
    0.0426*2 = 0.0852''
    0.354-0.0852=0.2687''
    Minor dia = 0.2687''
    This should give you enough to set it up just like cutting Imperial threads.
    Jim Dawson
    Sandy, Oregon, USA
    Oct 2018
    TILSONBURGE
    Quote Originally Posted by Jim Dawson View Post
    1.25 / 25.4=0.0492
    Calc TPI
    1 / 0.0492=20.32
    Major dia = 0.354''
    0.0426*2 = 0.0852''
    thanks a lot, Jim. so provided all that
    g50s200
    T20202
    G95
    G97S100M3
    G90G1X.38Z.1F50.
    G71X.2687Z-1. H.0426 (D..005?) F.0492 (U.001?) M73M34
    G80
    yeah?
    do you use M33 or M34? which is better? is it just preference?
    I am putting threads on an already hardened 3/8" bolt. I bought a long one so I could cut it off and put threads on the end of it.
    sorry if this is confusing
    Oct 2018
    TILSONBURGE
    is everything here radial ?? and no J value I take it since it's Metric ?or J is # of threads per inch
    and we figured it's 20.33? does the machine like decimals?
    Dec 2013
    Does your machine have a G32 threading cycle available? That's what I use.
    I normally set up the M33 or M34 in the CAM program and let it sort that out. In Fusion there is an option switch for this.
    - - - Updated - - -
    Jim Dawson
    Sandy, Oregon, USA
    Oct 2018
    TILSONBURGE
    - - - Updated - - -
    I think I tired it once but not G32
    I tried G33 which is like G92 in faunc correct? I tried G33 but the control doesn't like it. so I have been working with G71 instead.
    G33 X Z F J M23
    X
    X
    X
    seems pretty easy
    but anyway where in IGF is M34 or M33 determined? and if you noticed in my picture spinning clockwise is written as M41 .. .
    why?
  7. #7
    Dec 2013
    According to my list, the M41 is Spindle Gear Range 1, but I don't see a M3 (Spindle CW) or M4 (Spindle CCW) on your picture which is a bit odd. But understand I am no expert on Okuma or Fanuc for that matter. G33 (Fixed thread cutting cycle) by the description seems like a G32, but I'm not sure. In the example code below, the idea is to make a pass everytime a G32 is commanded, with a fadeout at the end of the thread. X and Z reposition at the start of the thread for each successive pass. Conversely, G71 combines this all into one line of code using a number of parameters. As near as I can tell, the M33/M34 tells the controller to fadeout the thread at the end (or not), not sure where this is invoked. Fusion 360 has a switch to fadeout or not.
    This is a Haas turning post from Fusion 360, 9mm x 1.25 thread, 1 inch long converted to Imperial units. 5 passes with a spring pass. This will run on my lathe, but your lathe might choke on it. If you choose to try this be very careful, turn the feed and rapid way down.
    (Thread1)
    N15 T100
    N16 G99
    N17 M22
    N18 G97 S200 M3
    N19 G54
    N20 M8
    N21 G0 X1.154 Z0.1969
    N22 G1 Z0.246 F1.5748
    N23 X0.3323
    N24 G32 Z-0.9916 F0.0492
    N25 X0.3491 Z-1. F0.0492
    N26 G1 X1.154 F1.5748
    N27 Z0.246
    N28 X0.3155
    N29 G32 Z-0.9832 F0.0492
    N30 X0.3491 Z-1. F0.0492
    N31 G1 X1.154 F1.5748
    N32 Z0.246
    N33 X0.2987
    N34 G32 Z-0.9748 F0.0492
    N35 X0.3491 Z-1. F0.0492
    N36 G1 X1.154 F1.5748
    N37 Z0.246
    N38 X0.2819
    N39 G32 Z-0.9664 F0.0492
    N40 X0.3491 Z-1. F0.0492
    N41 G1 X1.154 F1.5748
    N42 Z0.246
    N43 X0.2651
    N44 G32 Z-0.958 F0.0492
    N45 X0.3491 Z-1. F0.0492
    N46 G1 X1.154 F1.5748
    N47 Z0.246
    N48 X0.2651
    N49 G32 Z-0.958 F0.0492
    N50 X0.3491 Z-1. F0.0492
    N51 G1 X1.154 F1.5748
    N52 Z0.1969
    Jim Dawson
    Sandy, Oregon, USA
  8. #8
    Jun 2010
    SIAS?
    Cheers
    Roger
  9. #9
    Member deadlykitten's Avatar
    Jun 2015
    Antarctica
    hi, you don't need to re-set the machine, to be able to deliver a metric or inch thread; you need a bit of infos about :
    ... threading cycles ( pls find attached pdf )
    ... metric threads profile iso sizes ( there are tables all over the internet )
    please look inside attached pdf, for infeed patterns; some like to use M33 M74, whatever works usually i don't bother with such patterns, unless i have a nasty thread with calls for specific attention
    you may run some trials, to figure out the answer : program something in igf, inspect the code, and see how the machine performs ( inspect coordinates ) : these should give you an answer
    also, check definition of F & J in attached doc, at page 15
    about threading arguments, some programmers consider that they have to be integers ... but this is not true, at least on osp300
    maybe is an option for your machine, or maybe you did not write it ok ... i don't know, but i can say that i use g33 a lot
    i don't know for your machine ... normally, there should be a cnc parameter, or a igf parameter, but i don't know it's location for your machine
    and if you noticed in my picture spinning clockwise is written as M41 .. . why?
    since rpm is 111, with m41, 1st gear, spindle will output more torque
    it may be possible that a previous operation allready used M03, and igf 'optimizations' occur
    i am not near a machine right now, and even if i would, machine is in metric, so i won't be able to guarantee my code but, if you wish, i could show you how i program a 7tpi thread : G33 X Z F+25.4/7 G95
    you know, if you have futher questions, or curious about how others are doing things, there is an okuma forum, and it is pretty good : https://www.cnczone.com/forums/okuma/
    kindly
    we are merely at the start of " Internet of Things / Industrial Revolution 4.0 " era : a mix of AI, plastics, human estrangement, powerful non-state actors ...
  10. #10
    Oct 2018
    TILSONBURGE
    ah the good ol days
    i totally forgot about this post. i did use to have the LB15 1989
    what a PIECE OF S**
  11. #11
    Oct 2018
    TILSONBURGE
    Quote Originally Posted by RCaffin View Post
    SIAS?
    Cheers
    Roger
    OKUMA is like learning a different English or Australian English lol
    and "programming" is extremely boring too.
    tight machines though. probably the best for lathe.
  12. #12
    Jun 2010
    Been programming at all levels since about 1969. I quite enjoy it.
    I also enjoy using computer programming techniques to replace a 100,000 line CAM program with a 100 line hand-written one.
    Cheers
    Roger
  13. #13
    Oct 2018
    TILSONBURGE
    Cheers
    Roger
    programming with okuma. that's what i meant.
    this is not debatable i don't think
    as much as i hate Haas machines but man there is that control with easy typing, deleting, altering, COPYING vs
    TORTURE
  14. #14
    Oct 2018
    TILSONBURGE
    but when i had my LB15 and IGF and it never really bothered me much.
    the only thing i would change or add here is the "F" value. always keep it at 1.
  15. #15
    Jun 2010
    Ah, OK.
    I use Mach3 on a PC. There is NONE of that archaic big front panel with hundreds of keys stuff. That stuff is obsolete, but like dinosaurs it takes a while for the message to reach the head.
    Plus I get to sit down while programming!
    Cheers
    Roger
    Dons helmet.
  16. #16
    Oct 2018
    TILSONBURGE
    Ah, OK.
    Cheers
    Roger
    Dons helmet.
    you probably used tapes yeah? are we talking 1970s?
  17. #17
    Member machinehop5's Avatar
    Aug 2009
    ..the good old days
  18. #18
    Jun 2010
    I started with punched cards on an IBM7044 (I think!).
    Then paper tape on an Argus 500 in the UK, then PPT on DG Nova, then on DEC PDP-8, then on a glass teletype (ie VDT) on a DEC PDP-9L, then ... PDP-11s, then VMS, then ...
    The Flexowriter was a bit bigger than a Teletype though.
    Such fun.
    Cheers
    Roger
  19. #19
    Jun 2015
    Antarctica
    hy, okuma's are pretty high, controller has ease-of-use & other , at least compared to other actual brands, or with older okuma generations
    but true comparison, is not relative to other machines, but about how you feel when you work on it
    there are persons that really like okuma's, so much, that don't take it easy to work on other machines, and perhaps they wish for something more
    i understand when you say you are bored with programming ... sometimes i am also bored, especially for those parts that i know how to machine, but i simply hate that i have to spent time to create the program & setup & proof the machine
    if you have any ideas how to speed things up, just say; i have a list of those kindly
  20. #20
    Oct 2018
    TILSONBURGE
    lol no, borING
    not bored. but can you imagine if there weren't IGF?for somebody like me from Siemnse / Fanuc background. i persoanlly would've never been able to keep a job.
    in point of fact i found this and it will be useful to whomever is trying to do metric threading with Okuma
    M10 x 1.5 p
    F=1
    J=16
    N=1
    all you need is minor diameter.
