Axis Zeroing
Results 1 to 2 of 2
Thread: Axis Zeroing
    Member Rkjt's Avatar
    May 2019
    Default Axis Zeroing
    my small Chinese CNC machine is running off Easel software, will not home properly.
    X and Y are okay but the Z is 6mm too high.
    How can I fix this?
    Can some one help me? Thanks
    Ross
    Member cncmakers001's Avatar
    Jul 2011
    China
    Default Re: Axis Zeroing
    You might need to set the electric gear ratio of the Z axis driver, or adjust the limit switch on Z axis.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
Axis Zeroing
Axis Zeroing
