- North America Okuma MB-56VA doesn’t import the work coordinates
Flies Fast
Re: Okuma MB-56VA doesn’t import the work coordinates
The PX=0 & PY=0 should be on the same line as th CALL OO20 line... it would then place the calculated centrepoint in H2 work offset
Thank You very Much Sir I will try this tomorrow with the operator, and let you know.
Have a wonderful evening, and thanks again
Flies Fast
generally, the CALL OO18 & OO19 turns the probe on/off
next line (CALL OO10) is to setup the probe operation. (what/how to probe)
the next line (CALL OO20) is what to do with the probe results (set origin, judge if good/bad, etc ). There are many extra settings that can be placed on the OO20 line
I also think there is a OO30 feature, but I remember that this is more directed to probe calibration
Thank You very much, Sir operator must have hit the enter key by accident. The operators aren't really trained to program. I didn't have a clue, so your input saved the day. We also learned to look at the program on the bigger screen vs the small screen in that way we can see what is all on one line.
Thanks Robert
- You may not post replies
- You may not edit your posts
Forum Rules
