- Matsuura High Speed Commands
I've been working with a Matsuura H300 Plus at a new job. The machine has a Fanuc 30i controller. I know that G131/G130 turns the IPC/IZ-1/IZ-2 etc etc, high speed feature on/off, but can anyone shed some light on when I should be using which R values? And how to tell which of these high speed functions I actually have?
Also, as far as I understand, Matsuura basically uses their own high speed functions, in place of G08/G05.1, is that correct?
Thank you for any help, and let me know if there's any more information I need to provide!
- You may not post replies
- You may not edit your posts
Forum Rules
