The one hole with wobble is done at 300 ipm and the smooth one is 120 ipm
The 3rd photo is at 450 ipm and those should be straight lines with 90 degree angles.
We are a sign shop and purchased our first cnc machine from china to save money and get our feet wet.
The machine is a 5' x 10' 4 axis machine with a 12hp HSD ES951 Spindle and a Syntec 21MA Controller. Using V-carve software.
We are mainly cutting 3/4" melamine currently. I'm using a 1/4" compression bit with a single pass at 20,000 rpm and have no issues with it cutting. The accuracy issues is the small area clears in the job at 1/4" deep that are 3/4"x 2" in size. In order to get an accurate cut I am at 120 ipm which seems to be extremely slow. There was some play in the X and Y gear mesh which is now gone but I still have issues.
Any help to point me in the right direction would be great.
Thanks,
Tim
- Need Help!- How to increased machining speed while it were engraving a job
- Problem- accuracy issues
- Building for Increased Machine Accuracy
- Need Help!- Accuracy issues
- Problem- x2 accuracy issues
Have you tested straight line movements and measured them against programmed versus measured distances?
Check table and gantry for squareness, perpendicular, spindle tramming etc. Spindle runout can be checked. Looks like some of your mechanical parts are moving that shouldn't be. Eg: motor mounts etc.
Contrary to popular belief, on CNC machines duct tape and WD-40 do not work for fixing those that move and shouldn't and those that should that don't :-)
Photos of the machine and sample G-code might be useful to get more ideas of what you are dealing with.
What brand of servo motors and drives are on your machine, or is it a stepper motor machine, it look like at speed the control is not able to keep up, such a small cutout I would be surprised if you could do it faster than 120 IPM, you need to have quality motors drives and ground helical racks, or Ballscrews for your machine to go at those speeds in such short moves
Mactec54
most likely the acceleration too high
for this small distances, and machine trying to optimize the toolpath
a 3/4x2 inches part... not necessarly need 120 ipm
with 40-60 ipm it made same time, without rounded corners
I think that as you increase speed, your machine is flexing more.
Even with our $150,000 Morbidelli, we sometimes see similar issues with small details at high speeds, but not as bad as what you are seeing.
UCCNC 2017 Screenset
This is an arcade cabinet that I am working on and to get accurate cuts it’s taking a little over 25 mins to cut with 2 passes. Am I just being unrealistic with time or does that seem too long?
I'd try a 3/8" compression, and cut in one pass. I could do that in 10 minutes or less, but my machine probably cost 7x more than yours.
And use a larger bit to cut those pockets, and it should cut a lot of time.
Ideally in the future we were looking to get a Biesse Rover J because of the sign shop applications with an eot-3 knife and camera system.
Your machine has all the good mechanical parts to do it, it would depend on what encoder resolution they are using, and what the control can handle, with those Yaskawa drives the encoder resolution is adjustable, and if the control can't handle / control the Yaskawa full Encoder resolution, so there will be a combination of inertia from the speed and resolution at play,
It may seem to be a long time but they are quite big parts with a lot of small pockets, a lot would not be running over a 120IPM on the small detailed parts, the fact you can get 120IPM when doing the detail is quite good
I would say that it is more about the control not being able to control at those speeds, the out of position settings must have a high tolerance set or the servo drives would of faulted out with cuts like that, you have tool flex as well because of the high feed rate
You can see in the cut that the cutter is flexing also,( from to much speed ) so there are a lot going on when doing detailed work at high speeds, the machine may be able to do it, the cutter will not, I know of another machine similar to your machine, and they don't go over 80 IPM for detailed work
If you could use a larger cutter then you would get some more speed before you get cutter flex, there will always be a trade off between Control speed Inertia and flex
There may be a lot of people say they can cut faster than that, but in reality they are not, they may program those speeds but there machine will never reach the programed speed when cutting small detail work
There are expensive machines that can work at those speeds, but they too would have to use a larger cutter as well or they to would have tool flex just the same
Mactec54
I'd try a Vortex 3130XP, or 3135XP.
Or a 3150XP, which may allow you to cut the pockets as well with the same tool?
Thanks. I have a 1/2" compression bit here that I'll try to see if I get less flex. I just have to adjust for the difference of the radius of the bit in the detailed areas.
If you can use 1/2" that would be a good starting point, but if the control can't keep up with small fast movements you will still see some problems but should be an improvement with a 1/2" cutter
From the Vortex website you can get speeds and feed from there catalog page 14 they also have a phone app for speeds and feeds for there cutters
https://www.vortextool.com/wood-tool...n-spirals.html
Mactec54
I went with the 1/2” bit and shaved about 5 mins but the dust collector doesn’t pick up nearly the same amount of dust with the longer bit on it so after cleanup I think it pretty much negotiates the time savings. Haha.
I guess I can look at it this way. We are only a couple guys doing this so if it takes even 30 minutes to get it perfect it till saves me hours of doing this by hand and I can’t assemble and wire an arcade cabinet as fast as the machine can cut them.
There is a bit of play in the 4th axis which I’m regretting even having gotten now as we don’t really have a need for it. I feel that’s part of the issue. The factory is working with me on resolving that so I’ll keep you updated. I took a video but it’s too large to upload here.
