CNC Rookie - Having Accuracy Issues with increased speed - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
Thread: CNC Rookie - Having Accuracy Issues with increased speed
  1. #21
    Sep 2012
    Default Re: CNC Rookie - Having Accuracy Issues with increased speed
    Yeah.. I'm curious also..
    Remember there is a learning curve to all this...
    CNC machines are not magic genies
  2. #22
    Sep 2012
    Also.. it doesn't seem like you are using a spoilboard.. and that malemine looks more like OSB...
    You may be running too fast.. too deep with that 1/4" .. but there seem to be other issues..
    Is your GCODE/CAM outputting correctly?
  3. #23
    FixitFrank's Avatar
    Jan 2019
    I agree it looks like your typical 'servos can't keep up' issue.
    There's a lot going on in an arc between a pair of servos, the faster you run it, the less time they have to do it, and the more load you have, the harder it is to maintain the position dynamically.
    If you're not getting flex in the spindle, a good quick fix would be to just change your programming style. Go fast in the straight lines, and slow around corners.
    If you still get a bit of a wobble after a 60ipm corner into a 120ipm straight line, try adding a short 60ipm straight just after the corner so it can hold position, then go up to full speed.
  4. #24
    Member hanermo's Avatar
    Aug 2004
    barcelona
    From what the OP says ..
    the machine cuts fine at 120 ipm but not at 450 ipm.
    I suspect the issue is with the controller, and not with the servos or mechanicals.
    Maybe:
    Try running a straight path, manual gcode, and a 90 degree turn. No curves. This should be easy on the controller.
    Run it at rising speeds on the same material.
    One cut above another.
    There are many fine-tuning parameters on haas controls for similar stuff, for many reasons.
    I don´t know, but your control might also have abilities to pre-set for accuracy, acceleration, corner rounding, and other things.
    Your cam sw might also be the problem-causer.
    It might put out code that is computationally hard, like very many tiny arcs, perhaps.
    If you ran a test at near-zero mechanical load, this would indicate out differences due to spindle flex and load. Like a 0.1 mm deep cut, barely cutting.
  5. #25
    Sep 2012
    What Kind of controller is this anyway? DSP?
    Do you have pictures of the machine and various components?
  6. #26
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by Frankmali17 View Post
    His machine has a Syntec 21MA Controller this is more than capable of doing what he wants, these are a step up from most controls and are used on many CNC machines
    Mactec54
  7. #27
    Aug 2014
    How long is the 1/4" cutter you use ? Is it HSS ?
    I ask because it looks like tool deflection to me. Try a short carbide cutter.
