Help! What's wrong with this program?
Results 1 to 7 of 7
Thread: Help! What's wrong with this program?
    Default Help! What's wrong with this program?
    I wrote this simple program today for finishing a slot (I've omitted the first part which is roughing.). Please see the sketch and code I wrote. One problem which I can't figure out: The finished slot measures the correct width (.280) but the length is exactly .015 short at each end (2.220 inside the ends of the full radii instead of 2.250). Using a .250 end mill with D code at .250 diameter. Funny, that the amount the ends are short is the same as the amount that the sides are over 1/4", but I don't see how that can be related. See PDF sketch: Starting at point "A", CCW loop, finishing at point "B". Gotta figure this out by the morning! Thanks for any insight.
    N23 X2.3 Y0
    N24 G01 Z-.5 F80.
    N25 G41 D04 X2.345 Y0
    N26 G03 X2.485 Y.140 I.140 J0
    N27 G01 X.515
    N28 G03 X.515 Y-.140 I0 J-.140
    N29 G01 X2.485
    N30 G03 X2.625 Y0 I0 J.140
    N31 G40 G01 X2.3 M09
    N32 G00 G91 G28 Z0.
    N33 M30
    Attached Files Attached Files
    Flies Fast Superman's Avatar
    Dec 2008
    Antarctica
    Default Re: Help! What's wrong with this program?
    ??? some controls require Dvalue to be 1/2 cutter diameter ...ie D=0.125
    maybe your cutter is comped wrong
    ... try setting D=0 & running the path above the job.... does it follow the profile ?
    no... fix program....
    yes... now run it above, with the Dvalue
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by mwbridgwater View Post
    N23 X2.3 Y0
    N24 G01 Z-.5 F80.
    N27 G01 X.515
    N29 G01 X2.485
    N32 G00 G91 G28 Z0.
    N33 M30
    Sorry that would not work what I suggested you could try this though and change what you need to run this on your machine
    O3483
    N1G17G40G80
    T4M6
    M8
    G54
    S2850M3
    G90G0X-.005Y.0863
    G43Z.1H4
    G1Z-.5F20.
    G3X-.015Y.0763J-.01F14.
    G41G1Y-.985D4
    G3X.015I.015
    G1Y.985
    G3X-.015I-.015
    G1Y.0763
    G3X-.005Y.0663I.01
    G40G0Z3.
    M9
    G91G28Z0.
    M5
    M30
    Without cutter comp
    O3484
    N1G17G40G80
    T4M6
    M8
    G54
    S2850M3
    G90G0X-.005Y.0863
    G43Z.1H4
    G1Z-.5F20.
    G1Y-.985
    G3X.015I.015
    G1Y.985
    G3X-.015I-.015
    G1Y.0763
    G3X-.005Y.0663I.01
    G0Z3.
    M9
    M5
    M30
    Mactec54
    Quote Originally Posted by Superman View Post
    No, pretty sure that's not it. I know the machine uses the diameter for the D value, and the width of the slot is perfect - only the ends are each .015 short - that's what's so strange.
    Jan 2005
    To ways to fix it add .015 to each end of your slot and see what happens
    Or rewrite it without the cutter comp and you should be ok
    Mactec54
    Feb 2011
    try this
    I don't think that the first radius is complete
    by starting on one side completing the arc then coming back to it it should be complete
    the other thing that you could do is enter the finish cut on one side before the radius then when you are at the end of the cutting just g40 off the part to the center of the slot
    N23 X2.3 Y0
    N24 G01 Z-.5 F80.
    N25 G41 D04 X2.485 Y-.140
    N27 G01 X.515
    N29 G01 X2.485
    N30 G03 X2.485 Y.140 I0 J.140
    N31 G40 G01 X2.3Y0. M09
    N32 G00 G91 G28 Z0.
    N33 M30
  7. #7
    Sep 2017
    My guess is your finish pass is too fast on both ends. In my experience when cutting a slot, with cutter comp active, if the side/width is correct but the length is short then it is a finish pass speed issue. Simply slow down finish speed pass should fix this issue.
