Newbie HDPE parts cutting
Results 1 to 11 of 11
Thread: Newbie HDPE parts cutting
    Feb 2018
    Default Newbie HDPE parts cutting
    Hey there I’m a newbie to the CNC world. I am going to be cutting out 3/4” HDPE parts. What would you recommend for the best 1/4” endmill. What feed rate and spindle speed should I start at with said end mill. Any help would be appreciated.
    Dec 2013
    Default Re: Newbie HDPE parts cutting
    My prefered end mill for HDPE is an Onsrud O flute. I normally cut at 13,000 RPM, 40 IPM, 3/8 DOC using a 1/4 inch bit.
    O Flutes For Mechanical Plastics | Documents
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2018
    Up or down cut?
    Sent from my iPhone using Tapatalk Pro
    Feb 2018
    Or straight cut?
    Dec 2013
    I use an upcut. A straight flute doesn't shear the way a spiral flute does, you need the shearing action for a decent cut and proper chip formation. An alternative bit is the 2 flute, solid carbide router bits from Home Depot (Diablo) or Lowes (Bosch), both work well, and are available on a Sunday afternoon
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2018
    So the onsrud 63 series. What is different from 63-724,725,726...?
  7. #7
    Dec 2013
    Quote Originally Posted by Hyperryd View Post
    The length of cut.
    Series 63-700 | 1/4" Solid Carbide One Flute Upcut O Flute for Hard Plastics (Item 63-724) | Item Detail | LMT Onsrud
    Jim Dawson
    Sandy, Oregon, USA
  8. #8
    Feb 2018
    Forget it I found the chart. So 63-725 should work for a 3/4” depth. Right?
  9. #9
    Feb 2018
    Thank you for your help Jim. How about cutting 1/4” aluminum? What do you use for that?
  10. #10
    Dec 2013
    Maybe, I normally go with the next longer size to help with chip removal. In this case it looks like the next size is 1 1/4 cut length. Having said that, I have successfully used a 1 1/4 cut length to cut 1 1/4 thick HDPE, using 0.050 DOC on the final pass.
    Jim Dawson
    Sandy, Oregon, USA
  11. #11
    Feb 2018
    I got a little trigger happy and ordered 2 of the 725s. I’ll give them a try and if I need to, I’ll get the 726. 1 1/4” seemed like a big jump.
    Sent from my iPad using Tapatalk Pro
